We have a small SWG pool at a rental property and I'm struggling to control the heater remotely. I have a Rheem heater, a Hayward Pro Logic/Goldline AquaPlus panel, and a Aqua Connect Home Network box & antenna. The problem is that the WiFi-enabled controller only sort-of works, sometimes.
I don't think it's a WiFi issue because even when it's working correctly I can never control the heater settings. On its best days it will let me turn the pump or lights on/off. But most of the time my remote readout says: Base Station Not Responding. I don't know if this is an old system, a buggy system, or if it was set up incorrectly.
I'm concerned it was set up wrong because, on the physical panel, the Aux 1 button controls power to the heater -- not the heater button. Is this a normal setup for this system? Any suggestions? I'm open to replacing this system entirely if someone can recommend a better option.
