Hi all,
I have a ~12ish year old Hayward HP21002 heat pump for my pool. 2nd owner, this will be my 3rd season with it.
At the end of last season it started giving me an "LP" error, which can apparently be a number of issues -- low pressure switch replacement, circuit board replacement, leak in the refrigerant, total system replacement, things like that...
I did troubleshooting today -- I disconnected the low pressure switch at the circuit board and bridged those two connections. It stopped flashing "LP" on the screen and after a minute or two (I'm assuming when it decided to turn on the compressor and start the heating cycle), it immediately tripped the circuit breaker. I'll also mention that due to my dogs chewing on the unions (over the winter when everything was totally disconnected) where the heater connects to the plumbing, it's been leaking pretty good there for the past few days, but I've never had issues with it tripping itself when it's raining. I've since fixed the leaking issues and I'm waiting for that area to dry out in the meantime.
Any ideas what might be causing my heat pump to trip the circuit breaker when it tries to turn on? I'm definitely willing to buy a new low pressure switch, and maybe a capacitor or two if that might be the issue, but I'm really hoping it isn't something more expensive.
Thanks!
Thanks!
