Why the need to test FC above 10 ppm?
The k2006 without the *C* has much smaller bottles. (2.7X less IIRC). The larger kit reagents (TF100, TFpro, K2006C) go on sale each spring in the mid $40s at tftestkits.net. it's a no brainer to just get the set.
Individual parts always cost most than the thing you're fixing. You could build a replacement refrigerator from the repair parts, but it would cost several times more than letting Samsung (etc) do it.
Reactions: swimmynoodle
The only reagents I go through yearly are the OTO and Phenol Red. The rest of the kit I replace every other year with a refill kit when they go on sale from TFTestkits. I've yet to run out of anything else. Dave really did a good job of sizing the bottles to the amount of use they are needed over the two year life span when he created the kit.
Trying to understand CYA further, am I saying it correctly that once my CYA levels reach ~20 in my swim spa that my old FC level reading of 3 ppm without CYA will be obsolete?
I read "How do I use Chlorine in my Spa or Hot Tub?" and Chlorine/CYA relationship articles but dont fully understand.
I've been maintaining my swim spa FC at 3 ppm, CYA still at 0.0 because its a new fill, and im testing every day with K-2006.
So, once my CYA hits 20, should I expect to obtain much higher FC readings? Could I have a safe FC reading of 3 ppm with a CYA level of 20?
I feel like this is the last thing I need to figure out and then I should be good to go.
Thank you.
Yes.
Min FC is 2 for 20 CYA, plus UV loss, plus bather load.
Target range gets blown out of the water in a hot tub / small pool based upon use. If you take a couple soaks today you'll likely need to dose a couple times. And maybe for redisuals tomorrow.
  • proteam_gentle_spa_-_2018-5-11_1.pdf
Yes.
Thank you. If we have to also test for CYA, arent we going to blow through CYA reagents? They dont give much in the test kits.
For a reason. :) once you dial it in, it mostly won't change unless you add more or refill a bunch of water. So it's a monthly test, maybe longer.
I researched OCLT on TFP so that I dont repeat the question. I did the OCLT on my swim spa last night, cover was on (not that it matters at night), temp @ .80F.
Before Test @ 9pm (K-2006):
FC 3
CC .5
TC 3.5
TA 60
pH 7.5
CH 60
CYA 0 Didn’t test yet; waiting for dichlor to build up more to save reagents.
After test @ 9am:
Everything stayed the same expect FC went down to 2.5. Water is clear and looking great. I have not been in it for two days.
According to OCLT, .5 is a passing score. My question is, I read on TFP that chlorine needs to be replenished constantly; its just the nature of the beast. Is it simply an acceptable, understood chemical process that FC will simply drop (even in a covered swim spa protected from UV rays 99% of the time) and that I will need to add small amounts of chlorine (dichlor/liquid to prevent CYA rise) every couple of days, even if I don't go for a swim?
Thank you. TFP is the place to be. I feel so knowledgeable knowing all of these terms now :cool:🤓
:cool:🤓
Yes.
TIA for whenever you feel like we've provided you with enough value that you'd like help to keep the forum going. When i reached that point i was mid dumpster fire IRL. But when the dust finally settled, TFP needed it just as much and it helped just as much.
Towards the top, the article says, "Though using no CYA results in the least amount of chlorine loss, the fact is that you simply can't maintain a pool with only 0.05 ppm chlorine everywhere in it -- hence a minimum level is needed as a buffer."
Does this mean in a swim spa, covered from the sun 99% of the time, I technically don't need to worry about CYA levels and CYA levels with the relationship of FC?
Thanks
Chlorinated water without CYA is very harsh even at low FC levels.
Any chlorinated water you swim in should have at least 20-30 ppm of CYA to buffer the chlorine harshness.
Thank you for the information. If you could assist with the following question(s) I would appreciate it greatly.
1. Swim spa temp was 84F earlier today. I raised it to 90F and pH levels went from 7.5 to high off the charts hours later. I assume a correlation between temperature increase and pH rise due to warmer temp > dissolved gasses > aeration > pH rise. Should I expect it to be normal to have to add Muriatic acid more often while swim spa temps are higher to keep pH levels in check (lower)?
2. I need to get my CYA level to 30 ppm but its taking forever. I add about .12 oz dichlor every couple of days to maintain FC @ 3ppm. At that rate its going to take me weeks. Can I throw in a bunch of dichlor (I would measure how much I need to get CYA levels to 30), raise my FC levels really high to get CYA levels up, and then use hydrogen peroxide to neutralize/lower FC levels back down to appropriate levels?
Thank you!
Current levels (K-2006)
FC 3 ppm (15 drops x 0.2). Also performed 0.5 test with same results.
CC .2
TC 3.2
TA 60
pH Waaay off the charts. Dark red. 12? 14?
CH 60
CYA ~10. Performed drop test. Cloudy, but could still see black dot @ 20. Estimating 10 right now.
Use dry stabilizer to get your CYA up. Add it with the sock method.
Temperature does not affect pH. Aeration will cause pH to rise.
Oooh right, I forgot about the waterfalls and jets I ran. That for sure raised the pH. Thanks!
When you say dry stabilizer, do you have a dry CYA product recommendation? I know TFP does not like Clorox products.
