Why is my Polaris running on its side
rphillips
10
Irving TX
My Polaris is running, but tilted, running on just 2 wheels with the 3rd up in the air, or sometimes on its "head" with the back wheels in the air. Pump is running at 2845 RPM's, with a booster pump.
It doesn't runs straight/flat because of this. What is causing this?
I noticed that water is shooting out of the backup valve (sic) - is that normal? (see backup valve video).
My Polaris is running, but tilted, running on just 2 wheels with the 3rd up in the air, or sometimes on its "head" with the back wheels in the air. Doesn't seem like it runs straight/flat because of this. What is causing this?
Some of the internal jets may be clogged.
Reactions: rphillips
Thanks - I'll check that. Is it normal for water to shoot out of the "backup valve" as I show in the video link?
I don’t click links online, but the backup valve should
Periodically shoot water out of it and then stop for a bit. If it’s doing that, then it’s normal. But if it never stops shooting water then that’s not normal.
Thanks again - I'll check it again, to better guage when/how much it's shooting water out
Attached is a picture only (instead of video) with the hose pulled up above the water to see what its doing.
Get a new case for the valve, not the entire assembly, that's all that is usually needed.
A Polaris laying on its side is usually a damaged mast float that is filled with water.
Also, when the water gets cold, the tubing for the robot gets hard. During the winter my robot has more issues due to this, doesn't flow as freely with warm water.
