Why do you turn a SWCG down to 0 when adding salt
wayner
839
Toronto, ON
Jandy Aquapure 1400
Is it because immediately after you add salt you may get local areas of your pool with very high salinity and this could wreak havoc with the cells? So giving it 24 hours will allow entropy to set in? Or is there another reason?
I do it because the cost of the SWG is such that I prefer to avoid taking the chance of causing problems cause by it sucking up straight salt brine while it is energized.
IMO, pool maintenance is a "slow curve" sort of thing. Rapid changes in values are rarely dependable.
