ok, I see, if you are keeping your CYA up you will lose less chlorine, therefore need to generate less chlorine, therefore extend the life of the cell.
But you want to be diligent about maintaining your FC. Keep it towards the top of the recommended levels. If you let it dip low and get algae, it will be a bear to slam it unless you exchange water to lower cya.
SWGs also trickle the chlorine over time vs a slug all at once. I understood that all else equal if managed well it means Less chance of dropping below minimum therefore you can risk a higher cya
Yeppers! I panic if mine gets near min! If I know we’re going to have heavy use of the pool, I’ll chuck in a bit of liquid chlorine before or after to make up for it!
I actually keep just north of target, for me with 40 CYA it’s normally around 8 or 9. It’s safe all the way up to SLAM level so having that buffer means if I miss a day or two it really doesn’t matter.
