Unless one actually worked with a (obsolete) SwimQuip DEP filter (the one in the diagram), you wouldn't realize how pointless those torque specs are. Once the large O ring between the halves relaxed and/or became misshapen torque was gone. In practice, though not recommended, usually only half the bolts were ever put back in after a tank was opened.In my opinion, manufacturers should give torque specifications for all items requiring a torque to install.
The terms “hand tight”, “finger tight”, “Snug” etc. are vague and inexact.
I have used these terms and I will probably use these terms again because I don’t have torque specifications for most applications.
There is an art and a science to getting the correct torque even when you have a torque specification and a torque wrench.
Some people have a good understanding of these terms and a good feel for how tight to make different things from screws, bolts, nuts, fittings etc. and some people don’t.
Hayward, Pentair and Jandy do provide a few torque specifications for a few things, but for the most part, they do not provide torque specifications.
Torque settings have very little, if anything, to do with pipe fittings. "Hand-tight plus . . . " works for many/most applications. Another with regard to NPT fittings is "never less than three, never more than five" threads showing in a properly tightened pipe application. A good tech will find out what works for them and use it forever. They also know that a pipe fitting should not be tightened completely in. If it leaks, back it out and re-seal. That's why unions are so good to have. The type of thread sealant, which should always be used with NPT pipe, has a lot to do with it as well. If using Teflon tape, are you using the "good" stuff that meets MIL standards or the Home Depot special that is half the thickness.
High-temp pump unions are different as the threads are not tapered and they do get tightened until the O ring seals, not until the ring is flat. That allows for tightening at a future date as the O ring can harden from the environment and loosen with the vibration of a pump. Personally, I also use three or four wraps of Teflon on them as I don't like call backs for small drips.
