Try and not laugh while I describe some bugs in my pool.
I wasn't quite sure where to post this but here goes. A few weeks ago we started seeing quite a lot of a white, wispy residue with small (smaller than a pin head) brown dots in some of it--my first thought was it's pollen but the pool is in a screen cage. At the same time, I noticed that my chlorine consumption was increasing, eventually to about twice the normal level. My first thought was SLAM but I had done that the month before after replacing a dead SWG.
The chemistry using a Taylor DPD kit is right on: FC: 8, CC: 0,PH: 7.4, TA: 70, CA: 350, CYA: 70 and NaCl: 3600. OCLT: less than 0.5 PPM. The water is crystal clear. But, my SWG is set to produce about 2.5-3 ppm to hold FC. When I drop to my normal level of 1.6 ppm per day, I was losing 0.5 to 1.0 ppm/day.
I was about to try another SLAM yesterday but decided to skim the pool to remove 95% of the white/wispy stuff, which using a magnifying glass seems like it might be a bug, but it is tiny. This morning, after half a day of running after skimming, I measured the FC, it had fish by 2.5ppm!
Could my FC be oxidizing a teeny bug infestation leading to a high level of chlorine consumption?
The other possibility is that my two month-old Pentair 1.4 lb/day SWG is not producing the amount of chlorine I expect.
Any thoughts?
Any thoughts?
