Latest test results (tested myself):
FC 1.5 (lots of swimming and sun today, bumping back up shortly!)
PH 7.8
TA 110
CH 160
CYA 40
I’ve noticed some white flakes, but this evening there seemed to be a higher concentration of them floating in the water. Research seems to indicate that the flakes are calcium scale. Water has been balanced well since opening. One thing I did the past few days was brush around the water line of the pool to remove dirt from this area. Water is clear and I don’t see any visible calcium scale, except the flakes floating in the water. Photos are below of scale and if the area I brushed.
Is this calcium scale? Could I have brushed some loose? Anything to be concerned about? If so, what do I do about it? Thanks!
PH 7.8
TA 110
CH 160
CYA 40
