White flakes only in corners not on waterline
pjku79
0
Apr 17, 2015
164
San Antonio
Keep in mind, I am still a noob here. I will post my poolmath tests in a second.
I have had my pool stable for a month or two now with the water always being clear. I haven't had to add anything but stabilizer, salt, and muriatic acid.
Since I started, I have seen some kind of white substance in the corners at the bottom of the pool and in the spa. Sometimes it is easier to get off then other times. I don't get any white substance on the waterline.
My first reaction is that its probably calcium, but I would have though it would show up at the surface as well if that was the case. Thoughts?
Morgan
Build Type: Fiberglass
Volume: 11200 gallons
Latest Test Result Summary:
FC: 4.0 (2 days ago)
pH: 8.2 (2 days ago)
TA: 120 (2 days ago)
CH: 275 (2 days ago)
CYA: 50 (20 days ago)
SALT: 3000 (20 days ago)
CYA is actually in spec, I just forgot to log it. I think its about 80.
