I have a 24V 2440 Jandy actuator valve situated downstream of the Filter which diverts water either to the Pool (in "Pool Mode"operation) or to the Spa (in "Spa Mode" operation). It spends most of its life in what might be described as a "Spa Bleed Off" mode when, in what is actually normal "Pool Mode", it delivers approximately 80% of the water to the Pool and approx 20% into the Spa, to slowly turn over the water in the Spa via a small Spill-Over from spa to pool.
The valve is now some 13 years old and, apart from having an occasional, rotational, tantrum due to missing the limit-switch, it still works just fine.
However, for the past two to three months, while in its normal Pool/Spa Spill-Over Mode, it has been making a quite pronounced "whistling" noise. It appears to be working fine, but the noise is becoming extremely irritating (I recently replaced my old, noisy, pump for a nice new, quiet one and I'd really like to enjoy the longed-for absence of noise!)
Anyone know what might be causing the "Whistle"?
I imagine it could be due to the steady "erosion" of the diverter vanes, caused by it spending the vast majority of its life in the "interference" position of the "Spill-Over" Mode, but I really don't know. Indeed, if I turn the valve to the full-on “Spa Mode position, the whistling stops. (Maybe if there's a "Fluidics" guy out there reading this, he could educate me appropriately?)
Note: I do have a prior, same model, Jandy Actuator that I replaced a little while ago, and saved in case of the need to steal some parts from it, so I'd love to use parts from it if I could. Not just to avoid the cost of buying a new one, but also to vindicate my "Pack Rat" obsession to my wife, who constantly berates me for clogging up the garage!
Any suggested fixes (for the Valve, not the Missus!) would be greatly appreciated!
