The pump threw my breaker when I turned it on so re-tried this a couple more times with the same result. I checked the capacitor for damage but nothing apparent and i used a multi-meter to check for continuity and seems to be intact. I torn out the pump and pulled the housing off down to the impeller and the impeller turn in both directions with no resistance to speak of. I re-connected it to see if there was any difference without the diffuser and basket etc. it sparked from the motor through the venting and then threw the breaker within a second or two. Greatly appreciate any assistance.
