Which pump for a dedicated bubbler??
lvrpl
0
159
Connecticut
We’re working a new build - 26k gallon in-ground gunite pool - and have a single LED bubbler being installed in our sun ledge. I think we’re going to put the bubbler on its own pump so it can be activated at the same time the spillover on the spa is running. We’d have a dedicated skimmer providing water to the pump and bubbler (unfiltered - our pool builder said they do this all the time so hopefully that’s ok), and then the return line out to the bubbler.
What would be a good, suitable pump for this bubbler? We’d like it to have some good volume and pressure so it can shoot up into the air a foot or two for the kids to play in. We have all Pentair equipment, including an IntelliCenter. Thanks for any feedback - I’m having a hard time making sense of the various pumps for something like this (as opposed as a main filter pump - for that, we have an IntelliFlo3 being installed).
What does the bubbler installation manual say about the requirements for filtered water? A bubbler can easily get clogged with debris from unfiltered water and be difficult to clean out.
You should use a VGBA suction port on a pool wall for secondary pumps and not a skimmer.
You want a low head water features pump like…
Reactions: lvrpl
The IntelliFlo3 is more than capable of both simultaneously. I would save some money and increase the simplicity of your system by running the bubbler from the main pump.
Reactions: lvrpl
I went through the manual (it’s a Pentair Colorvision Bubbler) and didn’t see anything either way about the plumbing or water supply…but, of course, what you say makes sense that a skimmer would be more likely to clog it.
I’m a little frustrated with my pool builder on this one - I honestly knew no difference and they said this how they do separate water feature plumbing circuits (with a dedicated, unfiltered skimmer). Gunite went in about a week ago, so I suppose it’s too late to conver to a suction port as you suggest. Not sure why they’d do it this way - seems both more a little more expensive to do another skimmer (though probably by only a few hundred dollars) and more likely to clog the feature.
Thanks for the advice on the pump.
