Which Circupool model?
May 15, 2009
17
Mason, OH
Hi, so my compupool swg just kicked the bucket finally after 12 seasons so it's time to replace it. I'm going with a circupool but not sure which model between the edge and RJs. My pool is 20k gallons. Does anyone have experience with the different models and have pros/cons?
I ended up getting an RJ-60+. I have it set at 10% for a 15,400 fiberglass gallon pool. Only been running it a few days and was on my last 3" puck a couple days prior to turning on the generator and setting the percentage so i'm not sure a free chlorine of 6 is really from the SWCG or some holdover from the pucks.
Water specs right now:
PH 7.6
CYA 60
FC 6
CC 0
TA 70
CH 125
Suspect I may have to raise it a little as we use the pool more and create more load. I did the RJ-45+ upgrade to RJ-60+ for $10 option. Install was a breeze, no issues. Mounted the SWCG after the heat pump, and the flow switch right after the SWCG.
