Thanks for the reply mas. ?
FC testing directly across the pool from the inlet / outlet leads me to believe this. The difference usually ranges from 1 to 3 ppm. The cc is also usually higher by 1 or more. It happens often enough that I don't believe it is testing error. I think the +/- is about .5 with tf100 test?
The main reason I ask where is because I would like a skimmer, currently both outlets to pump are below the water line. I thought if I was going to make a change, maybe I could improve the flow a bit.
Note:
The difference is usually the most if the pool is not used and left covered for a couple days or more. Once I discovered the potential issue we never go more than 2 days without uncovering and either swimming or using robot a couple passes.
My swg is undersized, (couldn't pass up buying a couple on sale for $45 when we replaced small intex pump/filter with sand filter) so daily or every other day bleach is added. I now add to far side instead of at inlet to help a bit.
I usually test in the morning about 30 minutes after pump starts, before I turn on swg. Pump runs 12 hours a day, SWG about 10. Testing in the afternoons still showed a difference, not quite as significant.
The low testing area also gets the most sun, but I didn't consider that as too significant due to testing around 630 or 7am and pool is covered.
Thanks again and have a good day!
Mike
