Hey all,
I’ve been driving myself crazy debating on whether to get a liquid chlorinator (hasa) or a SWG. My CYA is way too high cause of the tabs. It’s not so much the money, it’s the worry that a salt water pool could cause damage.
My pool is probably around 30 yrs old, typical aluminum coping and steel walls. It’s in good condition and I just had the liner replaced a year ago (bought house last year) I’m worried the salt will sneak into the liner bead and damage the steel walls. I also worry about bonding. How would I know if my pool is bonded properly? I can see the pump is grounded to a ground rod. I have no heater. I hear mixed things about SWG and vinyl pools.
Do they not run below 70 degrees?
Anyone have a leak in which the salt water damaged the walls?
Should I convert or figure out a liquid dispensing way? (Def not pouring everyday lol)
