Hi all. I bought my house almost 10 years ago and I have a mystery I really think I need to solve. I'm in AZ, have a single speed pump. For the past several years, I've had a Hayward Phoenix 4x pool cleaner and it's time for me to order some new parts for it - tires & gears as well as some other pool maintenance stuff. Additionally, I have a Zodiac Cyclonic leaf catcher that does a pretty good job catching all the solid stuff that makes it up through the vacuum. The price of all the parts for the vacuum is pretty steep so I figured before I order parts, I should evaluate whether this is the best cleaner for my situation. I have palm trees directly over my pool so I get both strands of palm fronds and so many palm seeds that make it into the pool. Additionally, when we get wind/dust storms, dirt gets deposited all along the bottom. I also have dogs that kick little rocks into the pool during fetch and these rocks will often jam up the turbine on the cleaner, necessitating a rescue on my part. For the entire time I've had this pool, I've largely only been able to skim or vacuum - not both. I did try one of those skimmer baskets with a vacuum port, but that needed more maintenance/fiddling than what it was worth. I installed a SWG last summer to ease up on my chlorine use and it's been great. When I'm vacuuming, the pressure isn't enough for the SWG to kick on and generate, so that's also a problem I'd like to solve.
I'd really like to be able to skim and vacuum at the same time and by all appearances, my pool is plumbed with a vacuum port, though I've never used it as I've never been able to get suction to it. This is the mystery I'm hoping to solve. Over on the pump on the suction side, there appears to only be a single inlet that comes in from the pool. In my skimmer basket, there is a plugged port that I think is plumbed to the drain, but I'm not 100% sure - it's been a few years now since I last tried to solve this mystery. I've never posted about it though so I'm hoping this may help solve things. I'm hoping to solve this mystery in parallel to seeing what new vacuums are out there that the community recommends.
Anyone have any ideas as to how I might be able to solve this mystery? I'm not averse to digging to investigate.
Here are some pics of the relevant plumbing parts. Excuse the dirt - we just had storms and I'm working on getting things cleaned back up. Certainly doesn't help that my vacuum has stripped gears and is out of commission til I get new parts or a new cleaner.
