Hello all! I'm wondering where you buy your Jandy check valves (I need the 1 1/2"). I see them on the Amazon for $62, and possibly seeing some counterfeits/knockoffs or other junk getting into the supply chain? It looks like I'll need 2, and oh bother are all these small extras adding up into a ton of hidden costs...
I was looking at a Zoeller 30-0041 50psi check valve as an alternative but that seems like a really high pressure and these will be way downstream in my plumbing - past the pump & filter, then a flow diverter and through either SolarDome heaters (close to 30' of coiled distance) or a future gas heater (redirected via a diverter valve) - each path with get its own check valve, then a tee, a chlorinator, and up into the pool. This might not be the right application for that device.
Thanks for your help!
