I've finally setup my above-ground pool and it's working great but after about two weeks the pressure on my filter showed around 20 PSI (?) so I was told to backwash it. I didn't realize it, but it took drained quite a lot of water before it turned clean and I now had a second pool in my yard
Where do most people drain their filter/backwash?
Can I connect it to my house drainage system? (is this legal/safe?)
Because the filter is near my house, I thought about running PVC from the filter into the basement, through the basement, and all the way over towards my garage where I can setup an outlet to dump the water into my driveway. (the bottom of the driveway drains into a city drainage system)
