- Aug 15, 2022
- 12
- Plaster
- Hayward Aqua Rite (T-15)
I just did my weekly testing, and these are the results:
FC - 10.0
CC - .5
CYA - 40
pH - 7.87
TA - 100
CH - 225
SALT - 3000
I pulled the sample about 1 hour after my morning filter run (4.5 hours) stopped. Should I be concerned about the 10.0 FC? Meaning, should I reduce the chlorination % (which is currently 70% for 8.5 hours a day)? Or is that normal since I tested right after it turned off? If I can get away with lowering it and adding life to the cell (which is brand new), I'd be happy!
I've also noticed that my pH creeps up pretty significantly each day (.1 to .15). I've been adding the Pool Math prescribed acid amount, but not sure if it is normal for it creep so much.
As always, thanks.
FC - 10.0
CC - .5
CYA - 40
pH - 7.87
TA - 100
CH - 225
SALT - 3000
As always, thanks.
