After 8 summers with little to no problems, this year's pool season is turning into quite a challenge. Thanks to SLAM, my water chemistry is perfect and thanks to feedback here, I have a new pressure gauge on my clean DE filter. After I removed the obstructions from my skimmer baskets, cleaned the filter again, replaced the gauge, and turned on the system, it was working perfectly. Then I started to see DE return to my pool again. When I went to inspect everything I noticed some water trickling out of the backwash pipe...not much, but a slight stream. I have also noticed water pooling around the backwash valve handle and it becoming tougher to turn. It looks like there are a few things I could potentially replace here based on reading other posts, but not sure which items apply to my specific backwash valve. I posted a picture...would it be O rings, spider gasket, diverter? I feel like I'm replacing so many things, not sure which are the right things and which I'm just tossing money at.
