- May 31, 2012
- 966
- Vinyl
- Jandy Aquapure 1400
My pool was built about 16-17 years ago. I still have the original liner. The liner has a pattern and the pattern is about 95% faded on the bottom of the pool - especially areas not near the walls. On the sloped sides it is about 80% faded and on the walls below the waterline it is about 50% faded. Above the waterline there is very little fading - see the picture along with an extra piece of the liner that has always been inside so it should be the original unfaded pattern..
Does the liner fade from chlorine and UV exposure? I suspect that the fading may also be wear from cleaners, especially the Kreepy Krauly that I had for many years as when it would get stuck on my ladder you would see a wear pattern.
The liner does not appear to have any holes or leaks as near as I can tell. Is there any reason, other than cosmetics, to replace the liner now? My understanding was that liners typically last about 10-12 years.
I have always had a SWCG, I tend to keep my CYA at 60 and FC around 4. I live in Toronto and my pool is uncovered from about May 15 - Oct 15. In the winter it has a mesh cover.
