- Mar 31, 2022
- 66
- Fiberglass
- Pentair Intellichlor IC-20
When closing the pool for the season, how far can I drain my fiberglass pool? From what I understand there are 2 things to be concerned about when lowering the water of a fiberglass pool.
1) The pool floating out of the ground from high ground water and,
2) The walls bowing in of twisting from the lack of counter pressure the gravel backfill exerts on the pool.
My PB did install an 8" pipe next to the deep end of the pool to inspect the ground water, and if necessary, drop a pump down it; so that address the 1st concern. Burt what about the backfill pressure? Bottom line is you have to drain down some water at closing. Last year I drained just blow the bottom of my skimmer but with a rainy winter and early spring, the water was overflowing the pool when I removed the cover.
I would love to hear some opinions on this. Thanks.
