What’s this called?
BeachsideDDS
14
Solvang, CA
Anyone know what this is called?
Our pool builder initially told us to put chlorine tabs in here, but they never seemed to dissolve completely and the water in there smelled bad...
I cleaned out the chlorine tabs, as I’m transitioning to TFP methods. Just wondering what this “part” is called and what function it serves... thanks!
That's an auto-fill. The water level changes with the water level of the pool. If that float drops, it opens a water valve that directs water into the pool. It looks like a system made by Stetson.
That's your autofill pot. It adds water to the pool as the level gets lower. Works like a toilet bowl float valve.
Your PB is wrong! You should NEVER put chlorine tablets in there.
It kills me every day, to see the line of BS that is fed to people, that spend their hard earned money on a “dream pool”, only to be fed a total line of Crud!!!
DDS, you’ve come to the right forum to give you honest, tested, and well thought out reply’s.
