What wire/cable type to use from Easytouch to Heater
May 2, 2018
13
Santa Clara, CA
I'm reusing the heater (a Teledyne Mark V) while replacing the old timer system with an Easytouch system. (maybe I will replace the heater in a couple years - but the heater's still functioning OK.)
The heater had a "fireman switch" in the old timer box, and the cable is labeled "water resistant type ST" for the wire from the heater to the timer box.
I could reuse that same ST cable for between the boxes. I'd have to connect with THWN inside the Easytouch box because there isn't sufficient wire length.
Or I could go buy some flexible liquidtight conduit for between the boxes, and run THWN/THHN for the whole run.
From what I can tell ST isn't exterior rated. But the cable seems to be in good shape even though it's probably 30-40 years old.
