I need help with next steps. (i.e., do I add chlorine first, or lower pH?)
I'm new to TFP and just now learning the basics - thanks to Leslie's chlorine tablets (high CYA). I finally drained/filled my pool enough to get the CYA down from over 200+ to around 50. Now I need to know what to do next/first.
Here are my current test results (if I did them correctly):
FC - 0.0
CC - 0.0
pH - 8+
TA - 190
CH - 210
CYA - 50
*Should I take a sample to Leslie's to compare their results with mine?
I've also attached some photos. I have a nasty algae along the walls and floating in the water. I've removed as much as possible and have a new filter on order.
FC - 0.0
CC - 0.0
pH - 8+
TA - 190
CH - 210
CYA - 50
