Yes, that's why I mentioned you may need a little calcium. Just to get closer to at least 250.Thanks but I thought the new numbers posted by tfp has my CH pretty low?
Yes you did, sorry. Thanks againYes, that's why I mentioned you may need a little calcium. Just to get closer to at least 250.
ACCEPTABLE MINIMUM:
250-350
IDEAL:
350-550
ACCEPTABLE MAXIMUM:
550-650
WOW!! Beautiful pool! Your numbers look great but instead of 35 it would just be 30 CYA (even if it is in the middle). Since you don’t have a SWG, anywhere from 30-50 CYA is considered good. I try to keep mine at 40 but that’s just preference lolHello all, it’s that time again. I really never know which to do first. So I searched around a bit and most of you say get fc up so that is what I did. I had only fc of 1 before.
FC- 7
Ph-7.8
Ta- 50
Ch- 175
Cya- 35
I just opened this morning. Thanks View attachment 133124View attachment 133125
Thank you. Just put some baking soda in today to bump up TA. Going to alsoWOW!! Beautiful pool! Your numbers look great but instead of 35 it would just be 30 CYA (even if it is in the middle). Since you don’t have a SWG, anywhere from 30-50 CYA is considered good. I try to keep mine at 40 but that’s just preference lol
Actually, CYA is always rounded up, so if the dot disappears in between 30 and 40, call it 40WOW!! Beautiful pool! Your numbers look great but instead of 35 it would just be 30 CYA (even if it is in the middle). Since you don’t have a SWG, anywhere from 30-50 CYA is considered good. I try to keep mine at 40 but that’s just preference lol
Oops!! You’re totally right lol I don’t know what I was thinking!! ????Actually, CYA is always rounded up, so if the dot disappears in between 30 and 40, call it 40
