What to Add? Algae or no?
Jun 4, 2018
19
Commerce GA
So I have had this material on the bottom of my pool for about a week. It looks like dirt....not yellow or black. My water is crystal clear and other than those spots coming back up, I have had no problems. My question is how can I tell if it is algae and would my CC be 0 if algae was in the pool?
Last REadings:
FC: 3.7 CC: 0.0
CYA: 45
Alkalinity: 50
Ph. 7.5
Should I raise my Alkalinity? Could that be the problem?
The problem is the FC is too low. Your minimum before you add more is 4 FC. How you got 3.7 on a drop test is beyond me. It's not a factor of ,2 (25 ml sample) or .5 (10 ml sample) but it's too low regardless. 4 is the absolute minimum. When you add, you ought to shoot for 7 or 8 FC.
That stuff --- does it look like dust bunnies and does it go *poof* and disappear when you get close to it with brush or vacuum?
