I've been doing the TFP chlorine spa startup method for the past week. Over the last 5 or 6 days I've been maintaing my FC levels at about 6.0 by testing and adding small amounts of dichlor each day and keeping track of the number of grams of dichlor that I've added. Today, I added the last 8 grams which brought me to an accumulated total of 133g. According to PoolMath Effect of Chemicals calculator, that should've brought the CYA level up to 35 ppm which is where I want to hold it at.
I let the tub circulate with both jut pumps running for about 10 minutes after adding the dichlor and then tested for CYA. I got a result of less than 30 ppm CYA. If I had to guess, I'd say it was about 27-ish ppm but my comparator only goes as low as 30 so it's kind of hard to guess exactly.
So what should I believe here? The math says I should be right around 35 ppm. The test says CYA is maybe only around 27 ppm plus or minus whatever the margin of error is on that test which I suspect is not insignificant. Should I add a little more dichlor over the next few days until I finally do get a test reading in the mid thirties or should I just go with what the math says and switch to using only bleach for chlorine now that I've hit my theoretical target of 35 ppm CYA. Or should I have circulated more/waited longer to test after adding the last bit of dichlor?
