Moved from ...upgrade pump?
I wanted to piggy-back on this thread because I'm in a similar situation. I don't have water features, but will be getting a Gulf Stream heat pump. I'm also buying a Dophin robot cleaner. Should I buy a VS Pentair for $699 or just get a retrofit 2 speed pump? If you suggest the retrofit, which pump motor do you recommend? I currently have an unknown age Hayward Super Pump. I'm near Boston MA.
Thanks!
Thanks!
