Every month I go to the local pool store to check their numbers with mine. Just on a curious level. Since March, my phosphate level has been rising. Currently, it is around 530, from 200 in March, per the pool store. I currently use the K-2006 test kit and there is no testing for phosphate. Is there a need to buy a phosphate test kit yet and any recommendations? I read online that you don't really need to worry about phosphates level until it is over 1000.
The pool is only 6,000 gallons and has an automatic cover and the water is covered 20 out of 24 hrs per day. Some days we don't even use the pool. My FC is always at the required recommendation number per pool math. Currently, it's at 8 with CYA at 50. CC is always perfect. I tend to have the FC at the high end per Pool Math. Since the pool is small adding liquid chlorine is not an issue. My water is super clear and I'm pretty anal about brushing at about 2-3 times per year.
I did some reading online at TFP and there were some recommendations for phosphate remover. Do I wait until fall/winter and if its close to 1000 then go ahead and use a phosphate remover?
