So I have a rebar rust spot & my pool plaster is about 17 yrs. I've decided to replaster & fix the rebar. My expectations from reading is to either drill down to the rebar & cut it out or put the rust inhibitor around the rebar but the contractor told me that is not necessary. He cuts 2 lines at the area & put a bond tote for stain prevention, is this correct? He said that's all need to be done. I am not very confident on this solution & want expert opinion. TIA.
How do we know if it's a rust stain vs rebar rust? My situation is I drained the pool, drilled small whole in the affected area & using sand to remove the rust. After about 5 hour the rust stain shows up again in the whole I've drilled.
