A house with a pool near us is for sale. I would consider buying it if the pool worked ... it does not, per the disclosure form, and per neighbors has not for many years. Nebraska, so true winters. It is empty now and presumably has been for years. Attaching some pix ....
1. what is the process to figure out if the plumbing to the pool works when there is no water in the pool?
2. I am assuming the cracks in the concrete are bad, but not sure if they necessarily mean leaks .... again, how is that determined if there is no water?
3. Assuming concrete cracks are major problems, what i the cheapest fix for the long-haul?
a. can we line it without really fixing the cracks other than maybe filling them?
b. can we concrete over it, or do a spray gunnite, etc over it for cheaper than whatever other fix there is to the actual pool?
c. if we wanted to keep it concrete would we need to remove what is there and start over in terms of the pool itself (ignoring for the moment the water system to the pool/from the pool)
My only experience with pools is above ground ... need some knowledgeable thoughts on the viability of this pool before I consider picking a fight with my husband to consider this purchase. Obviously we would not buy it til an on-site inspection can be done, but looking at it tonight so wanted a bit of a preview for how to fix a cracked concrete pool from you experts if you have a sec. TIA.
