What is the correct way to plumb pool components?
IMV8N
80
Las Vegas
I broke the union nut on my pentiar pump. I decided to just build a new connection from pump output to filter input. Previosly the pipe was a straight with (2) 90 degree couplers. In reading about pool plumbing I saw that hard 90 degrees couplers shouldnt be used. Instead to use the 45 degree couplers. I only need to go about 2 feet from the pump to filter. I was just wondering what the professionals would do in this instance? Also any tips on getting the mesaurements right. I tried to fix the old pipe by cutting the broken section out and cementing on a new section but I found that when you dry fit the pipes they only go in about 75 percent of the way where as when you have the primer and cement actikng as a lubricant for few seconds the pipe will seat all the way in the couplers. Anyhow my attempt to install the frankenstein pipe wasnt fitting flush so that is why I am starting from scratch. 20220615_194047.jpg20220615_194052.jpg
Use 90's and make it easy on yourself. A few 90's make an insignificant difference.
Use "2 PACK -CMP Hi-Temp Union 2" inch 2MIP x 2" inch PVC Whisperflo & Intelliflo - 2 PACK" for your pump union.
From PVC Repair - Further Reading
Prefit the pipe using soapy water to get full penetration. It's still hard to get it to fit up but you have to do this to get a trued up and square installation with good penetration at each fitting. Then when everything is square mark the edges of each fitting with a pencil. Also mark a perpendicular line from the pipe to the fitting. Use a pencil not a magic marker since the glue will dissolve anything other than a pencil. When you glue the fittings line them up with the marks. The pipe will be perfectly square and look like a pro did it!
Was wondering if I could get someone to let me know if this is correct at best or functional at worst? The previous pipe was just a straight pipe with (2) 90 couplers. I couldn't replicate that for some reason so this was my next next best effort. I haven't glued them yet. Any suggestions would be appreciated. 20220616_185331.jpg
