- Jul 22, 2023
- 267
- Plaster
- Pentair Intellichlor IC-60
Never use a metal measuring cup around pool chemicals.Yeah, probably don't need the metal measuring cup.
Hmm....the PB told me this will be part of the return, no actuator on that return. I'm ramping down to 1150 rpm when laminars and waterfall are not on and bubbler is about 5-7 inches during those times.Turn off the bubbler and any other aeration device - no need to run it/them 24/7. The aeration will cause the pH to rise.
Post a few pics of your equipment pad from a few different angles so we can see your setup.Hmm....the PB told me this will be part of the return, no actuator on that return. I'm ramping down to 1150 rpm when laminars and waterfall are not on and bubbler is about 5-7 inches during those times.
Seriously, get a plastic measuring cup with a handle. You’ll thank me laterI got the coin but I'm frugal unless I get value for the coin ;-)
Yeah, probably don't need the metal measuring cup. Can use a solo cup I guess. But will take the advise and estimate and just tell PM I added the recommended amount.
May just get the scale. PB bought a Spartan brush, so may just get the pro tuff pole for now.
The SWG is in the signature already. However, it isn't hooked up as yet since I was waiting for the at least 30-day rule.Post a few pics of your equipment pad from a few different angles so we can see your setup.
The bubblers, laminars and waterfall should be set up to be able to be turned off.
These items should be off unless you are actively using them. They should also be run for a few minutes once a week to allow fresh chlorinated water to flow the lines.
Use of anything that aerates the pool water will cause pH to rise.
Keeping the TA in the 50-60 range will minimize this pH rise.
Test/post the pH, TA and CH of your fill water (same water source as your autofill).
What model number is your SWG? Add that info to your signature.
Do you use a specific bucket and measuring cup? Just realized my 5-gallon paint bucket has a hole.Seriously, get a plastic measuring cup with a handle. You’ll thank me later
I have one in the pool bucket & one in the hot tub bucket. I only ever need small doses of MA.
Speaking of coin…
You don’t have a pool cleaner listed in your impressive signature…
Btw - we love pics so show us this fantastic pool![]()
Fill water:You have "SCG: Pentair Intellichlor SWG (new pool, not on yet)"
List the model number - like IC40, IC60, etc.
What is the pH and TA of the fill water?
Oooh Fancy!Do you use a specific bucket and measuring cup? Just realized my 5-gallon paint bucket has a hole.
I tried to get an in-ground pool cleaner but PB wouldn't so it. I asked here and since I have a screen enclosure, a robot was not needed, not looking to have to put in and take out a robot if it doesn't add too much value.
View attachment 522109View attachment 522110
yes, but it is a pain to use and don't see that it did anything much for the hassle. Just brush floor to drain.Hopefully you do have a manual vac correc
You are playing a game of close enough, not match the numbers.
