Your Chlorine is way to low!!!No, I do not have a lawn. A week ago, the solar fell blew in the pool. Also, the power company put up a big metal pole at the corner of our property.
Yes, I have tried brushing it and nothing happens. I’m going to shock tonight to see if that helps. Ph is 7.5, chlorine is .5, total hardness is high at 150
They might have cut the metal or used a grinder, which can create tiny metal particles.Also, the power company put up a big metal pole at the corner of our property.
I have always struggled with chlorine levels. I use 2, 3 inch tablets in a floater and replace once a week. What else can I do?Your Chlorine is way to low!!!
2 pucks per week adds 7 ppm FC PER WEEK. You likely need about 4 ppm FC PER DAY right now.Use liquid chlorine.
What product are you using to “super shock” ?Well after super shocking the pool and running the pump all night
We recommend using liquid chlorine for daily chlorination & maintaining target range fc levels according to your cya levelI have always struggled with chlorine levels. I use 2, 3 inch tablets in a floater and replace once a week. What else can I do?
