- Jan 24, 2021
- 145
- Plaster
- Jandy Truclear / Ei
Hello everyone. I have a newly built pool and it’s my first time around with both salt and automation. I have the Jandy IAquaLink RS4 automation and the TrueClear SWCG. The PB did not wire the SWCG to the automation, I assume because I am maxed out on outputs (two separate lights, two pumps and a spa blower). Is there any real benefit to being able to control the SWCG from the automation? As I said, I’m new to salt pools, but it seems like you would only adjust the salt percentage seasonally, once you get everything set up.
