What do I select for Sanitizer in the PoolMath app if I use CalHypo Shock Treatment?
Hey Cilo and Welcome !!!! :wave:
To see the other options, including several strengths of cal-hypo, scroll down the list.
Welcome to TFP!
Not do derail the topic, but I'm curious how are you managing your CH levels? Most people in Arizona have trouble keeping their CH down when using liquid chlorine or an SWG, it must really rise fast if you're adding calcium every day.
Welcome to TFP! :wave:
Don't use CalHypo to chlorinate in the PHX area.
Our fill water tends to be high in calcium to begin with. And with our high evaporation rates the calcium level of the pool water will increase pretty quickly.
How are you testing your pool water?
Test Kits Compared
Post a full set of current test results from your own test kit
FC
CC
pH
TA
CH
CYA
Salt (if you have a SWG)
Water Temperature
Welcome to TFP!
I don't add calcium every day. I add about a 2 bags of CalHypo every week sometimes a bit more frequent. I just refilled my pool and Calcium was in the 80s to begin with. I usually drain my pool every two years to avoid high Calcium numbers.
Test Kits Compared
FC
CC
pH
TA
CH
CYA
Water Temperature
Hello, thanks. Liquid Chlorine does not hold here in the Phoenix area so that's why I use CalHypo. What are your suggestions for chlorine type for Phoenix? I am using Taylor kit k-2006.
You will evaporate 1 to 1.5 times (or more) of your pool volume yearly.
Solids (calcium included) will remain.
Don't use CalHypo or an other type of solid chlorine in the PHX area.
Test you fill water with your own test kit?
Report ph, TA and CH here.
A SWG is the easiest and cheapest way to chlorinate a pool in the desert.
Liquid chlorine works just fine in our area - I used it for 10+ years before converting to a SWG.
If liquid chlorine is burning off that fast for you, possibly your CYA needs to be increased. I ran my CYA at 50 (sometimes 60) when I used liquid chlorine.
Post a full set of current test results as requested in post #5
I'm not talking about the options to know how much to add but the Sanitiser type question that is under Settings.
Ahhhh. OK. Use liquid chlorine for the pool settings sanitation type.
Its because SWG pools have higher CYA targets. The other forms of chlorine are all the same.
Reactions: cilo06
ph: 8, TA: 80, CH: 100, Temp: 84.4 F
I have to look for a SWG.
Do you fill with softened water?
I really don't know. My house has a water softener system but unsure of how it works, meaning if the water from the hose is also softened. I bought the house with the water softener system so I don't have any information on that or experience as to how to check. I did just drain and fill again, Calcium was in the 80s when I filled with new water. IT was a complete drain and fill.
If you can find your autofill or wherever your fill water enters the pool, take a sample of it and then using your test kit , test for CH. If it is near zero then that is softened water.
Reactions: cilo06
Post a full set of current test results using your Taylor K-2006
FC
CC
pH
TA
CH
CYA
Water temperature
If your autofill uses soft water, there is really no reason to have to drain the pool every 2 years.
You use of CalHypo is causing your CH increases.
If you don't have automation, a Circupool RJ series SWG would work.
If you have automation, you will want to use the same brand of SWG as the automation so it all works together.
You want to size the SWG for at least 2x your pool volume.
Tell us a bit more about your pool by filling out your signature with pool, all pool equipment (include manufacturers and model numbers) and test kit info.
This assists us in providing your help without the need to ask you each time for this important information.
