- Jun 1, 2018
- 16,000
- Vinyl
- Hayward Aqua Rite (T-15)
The 1ppm fc level is only 1ppm away from zero. Minimum for a cya of 30 is 2ppm. Target is 4-6ppm.I did think about offering our pool, though we live about 30 minutes to the east of this pool. (I work in the same town as the lessons.) I don't know that it would work for the instructor. Perhaps people would choose that over just cancelling the rest of the lessons if it came to that.
I have also sent the instructor the link to this thread, and I think she'll pass it on to the homeowner.
Ok, here are my test results:
CYA: Roughly 30 (The dot was pretty faint at that level, I would have to guess that if the tube were taller, it would have registered somewhere in between 20 and 30 and therefore round up to 30 anyway.
FC: 1
CC: .5-1 (It might have turned back to clear with one drop, but I wasn't totally sure so I added a second drop.)
PH: 8.6 (Yes, that high, checked with my meter and then the dye test and it was off the chart red.)
TA: 130
CH: 175 *
*The pool is completely tiled and grouted, every surface in it-walls, floor, etc). So do I assume that it would be treated like a plaster pool for the purposes of things like CH? If so, that is pretty low I think.
My guess is that the owner is assuming that 1 PPM chlorine is within the range and they'd naturally want it to be low to protect the babie's skin (I can see how that would be an easy conclusion to come to). So I'm thinking that probably the best bet would be to raise the chlorine to at least 6 PPM each day after the lessons, that would kill off all the baby pee and let it fall into an acceptable range by the next morning (though that should still be checked in the morning, at least for a while). Of course, using liquid chlorine to avoid adding more CYA as it seems to be about in range of recommendation for an indoor pool. Though maybe she could use up some of that bucket to avoid waste and still be in a decent range?
FC/CYA Levels
Running it at 1ppm is unsanitary - letting fc get too low during use risks person to person transmission of pathogens. Dosing higher afterwards does nothing to mitigate that risk.
GreatI also see on that CDC page that PH out of range can contribute to hot tub rash, though it doesn't mention if the bacteria that cause it prefer it high or low. I do also see that high PH can cause skin itchiness.
So I texted the instructor and recommended she pick up some acid on the way there in the morning, and add enough to bring the PH down so that she isn't having that be a contributing factor to itchiness.
Some types of stone are just bad ideas to use for a pool - salt or not they will deteriorate. If its fine now it should remain fine with a swg. The low ch is liable to a worse effect on the surfaces/grout than the salt content will.The instructor said something about the homeowner thinking that a salt water chlorine generator was not recommended for their pool because of the tile. Is there something to that? I haven't seen anything like that here at TFP, other than if it were new plaster you have to wait a while before adding salt (and using the generator). This is not a new pool.
Bromine can be harsh for some - you also mentioned that there is some uv exposure for this pool. There’s nothing to protect bromine from uv like cya does for chlorine so it may not be the best solution in this situation.Also said that the homeowner was willing to consider switching to either bromine or baquacil (I don't remember which she said, are they different chemicals? Or is Baquacil a name brand for bromine?) Is there any advantage to that?
Baquacil, SoftSwim, Revacil (biguanide) pools are expensive to maintain & often end up with trouble after a couple years (white water mold, pink slime, etc.) so it’s not recommended here. It is not the same as bromine although some components of the system contain bromine/bromide.
Bottom line is that it’s not the type/method of sanitizing that is to blame here. It is inadequate dosing of the current sanitizer.
