What are these lines?
For a court case, you really need a qualified expert to be able to give expert testimony about whatever it is that you are trying to prove.
Do you have any proposals from any pool companies to get the pool back to 100% working condition?
We have two proposals and we have established by speaking to these two pool companies that the base of the spa is pulling away and cracking the pool in two. In the image you can see the tilt. This did not happen overnight - but rather has been pulling away slowly through the years.
What a nightmare! I hope this resolves in your favor. Here in CA I was told by my agent that the homes are technically sold “as is” and that the inspection is all you really get. So then you have to go to the inspector if you discover large issues that they should have picked up as the seller is not responsible for anything once the sale goes through. Sorry you are going through this.
Thank you! The reality is, all the Seller had to do was state that there were issues - and it was up to us to buy the property or not. But they lied and have refused to produce water bills for the last 5 years - even though they can easily be requested from the City.
  • Wow
Reactions: kul
Ah, more remedies available for you! If I was in your position, I would certainly contact TREC (Texas Real Estate Commission). I have dealt with them in regards some legal work I was doing and they don't take kindly to their agents (and especially brokers) lying. I would also seek out the broker (or the agent if they are also the broker) and ask about errors/omissions claims/insurance. I am not licensed in Texas, so this is NOT legal advice. :)
I have all the details on the Seller's real estate license, and if we win in court, I will definitely report her. We feel completely bamboozled!
This is a core sample showing two layers of plaster and then the concrete shell below.
The two layers are slightly different enough to distinguish the separate layers.
You only need to go about 1 to 2" deep to get a useful sample.
This assumes that they plastered over the existing layer vs. removing the existing layer before replastering.
Ask if the existing plaster was removed (Full chip out) or if the replaster was done over the existing layer.
Did you have a home or pool inspection before buying the home?
Thank you! I'm finally getting an idea of what they had done to the pool - which was basically cosmetic. We had the house inspected and we did not have the pool inspected. The Seller stated in their Disclosure that the heat pump for the pool was broken but everything else, including the pool was in working condition. ALSO, the Seller is a realtor, so we felt there was an added level of responsibility in telling the truth in the Disclosure, because this could cost her her license. We were wrong.
Reactions: JamesW
Did the inspection report include or exclude the pool?
Did the home inspector recommend a separate pool inspection?
What is the total price?
What is included in the proposals?
The inspection did not include the pool - and I realize after having three different pool leak specialists come out (after we did our own replaster) that it would have been impossible with one inspection to note all the leaks. The proposals included removing the wall where the spa is, rebuilding that wall (basically getting rid of the spa), replaster and deck work because the deck is all warped from the pull of the spa. Estimates are up to 100K for the complete job. This has been a disaster - and I hope we win in court!
Any property I've sold I have always made sure this box is checked on the TREC form. It's not a total absolution of responsibility, but it puts more the onus on the buyer before the sale is finalized.
D. ACCEPTANCE OF PROPERTY CONDITION: “As Is” means the present condition of the Property
with any and all defects and without warranty except for the warranties of title and the
warranties in this contract. Buyer’s agreement to accept the Property As Is under Paragraph
7D(1) or (2) does not preclude Buyer from inspecting the Property under Paragraph 7A, from
negotiating repairs or treatments in a subsequent amendment, or from terminating this
contract during the Option Period, if any.
(Check one box only)
____ (1) Buyer accepts the Property As Is.
____ (2) Buyer accepts the Property As Is provided Seller, at Seller’s expense, shall complete the
following specific repairs and treatments:
(Do not insert general phrases, such as “subject to inspections” that do not identify specific
repairs and treatments.)
That's all well and dandy, but doesn't cover a material misrepresentation by the seller (who as an agent KNOWS or should have known better). Some would call that...FRAUD and the TREC boilerplate contract ain't gonna help.
Reactions: Melissa2022
I don’t have any faith in home inspections after some of my experiences. First house we bought, there was a crack in the foundation. Inspector swore up and down that it was just cosmetic… 6 helical piers and $13k later the house was in no danger of collapsing. The house we have now we paid for a pool inspection. Inspector said pool was fine. Later discovered that it needed a new liner and the fiberglass stairs needed to be replaced, the electrical wasn’t right and the filter leaked. So again $13k later (don’t know why it’s always $13k with us) pool is awesome. My experience with home inspectors is that they usually find stupid easy to fix stuff that just stresses people out for no particular reason, but will miss the really important stuff.
I sell lots of estate property and can make no warranty, no prior knowledge, so make no warranty. Fraud and misrepresentation comes into play when a seller hides something on the disclosure, if one is used. So, if I make no warranty, and disclose no issues, then it all gets back to what I knew. With property I have never owned, it would be hard case to make that I committed fraud. With this case in hand, sounds like that's what is trying to prove, prior knowledge, and may very well can, hopefully. But, I will reiterate, to contractually state that you make no warranty and its agreed, it puts more onus is on the buyer than the seller come dispute.
Reactions: HeyEng
Sounds like if seller isn’t readily providing you with the information you are requesting, there’s something fishy going on. Ugh. So frustrating. Keep us posted on how this resolves.
All true, but from what the OP has posted, it appears that the seller made a material misrepresentation. Nonetheless, what a mess!!! Unfortunately, this is a great example as to why a through pool inspection is a must when buying property with one.
Did anyone say this can be fixed? while saving the spa. I'm asking out of curiosity, not trying to give you anything more to stress about. I'm new to pool ownership and stuff like this is what keeps me up at night myself
I actually called the company that supposedly did the replaster, but they won't return my calls.
Leave them a message on voicemail, text and any other way that they can cooperate or you can have the court issue a subpoena to make them answer.
You can also file complaints with the city and state consumer protection agencies and the city and state business and contractor licensing boards if they choose not to cooperate with your requests for information.
If the seller really did have the pool plastered, they would have something to prove their story like a cancelled check, receipt, a withdrawal receipt for cash from their bank, emails pictures or something.
Probably the spa can be saved if some sort of extra support is added to stop it from leaning - but I don't even want to imagine what that would cost!
And I would add getting copies of the water bills. These would show if extreme amounts of water were consumed - which is what happened in my case! Had we asked for copies of water bills, we would have noted summer months with beyond excessive water usage, for a home with two adults. They were basically refilling the pool, instead of repairing the pool (i'm talking one month 96,000 gallons of water). And during the months they no longer lived in the house - thousands and thousands of gallons of water (for an empty house!).
  • Wow
Reactions: dsmrph and kul
