My plan is to use my well for topping off. I tested the water supply to the house and got very similar numbers with a higher pH.
pH: 7.5
CH: 60
TA: 200
We get about 50" of rain annually in Houston but it tends to come in bunches. The summers are hot. The pool we had at a previous home in the Houston had a lot of evaporation during the summer.
@Dirk , what is the automated acid dosing system you use?
With that much rain, your CH70 fill water will likely be easy to manage, and would make a softener unnecessary. You'll probably need to
add calcium periodically, not drain it off. But our testing/dosing methods here at TFP make managing all the pool chem's a breeze.
I have a 100% Pentair pad. So I use a Pentair IntellipH (IpH). It installs as a companion to the Pentair IntelliChlor (IC), and they are well designed to work together. The IC must be present for the IpH to work, the IpH cannot be installed stand-alone (not without DIY modifying it, which is possible). For example, the IpH stops the IC from dispensing chlorine while the IpH is dispensing acid. The IpH also used the IC's built in flow and temperature sensors: the IpH won't dispense if the IC determines flow is too low, or stopped altogether, and the IpH won't dispense when the IC is down for the winter (when the water is too cold). That latter "feature" is actually a "con" for the IpH, and I modified mine to dispense year-round, even when my IC is not running, but that's a DIY kluge I developed, not something available with the stock setup. The IpH piggybacks off the IC's power supply, which is the primary reason it isn't stand-alone. But this is a good thing: if the IC is wired correctly to only run when the pump is running, then the IpH gets the same safety-feature benefit (of not being able to dispense when the pump is off).
The IpH tank is particularly well designed, very easy and safe to fill, bolts to the pad, holds about four gallons, and has a venting system that minimizes the effects of acid fumes on your pool equipment. The acid pump is part of the tank, so it makes for a streamlined all-in-one system on the pad.
Full disclosure: the IpH unfortunately has a known "bug" that can cause both the IC and the IpH to stop working. It's a problem with the circuit board that Pentair has yet to address. Pentair honors the warranty for this problem, and there is a relatively simple DIY preventative fix for this, if you're at all handy. It doesn't happen to all setups, and happens more often in systems that have the bigger ICs (IC40 and IC60). The problem is related to the amount of current the IC is pulling through the IpH. Not a stellar "feature," for sure, but it wouldn't keep me from getting another one, or recommending one to others, because their is a work-around fix.
Stenner also makes acid dispensing systems, as does Hayward. Never having used either, I can't detail their pros and cons. The IpH definitely has several safety features that would be challenging if not impossible to recreate with a Stenner system. I don't know if the Hayward system has any of the same safety features or not.
