Have you calculated how much the cya will increase if you use all of those tablets?
There is no such thing as a chlorine only tablet. Most are trichlor and add stabilizer. There are very few that are Cal hypo and add calcium
Cal-hypo tablets don't dissolve completely and tend to leave a gloppy mess behind.
Hi, Elaine. You really can do this!
If this were my pool, I would fill it, test PH and FC. Then add the CYA granules via the sock method, and use Pool Math to figure out how much plain liquid chlorine (bleach) to add. Check PH and FC daily, dose liquid chlorine daily according to Pool Math.
If PH goes to 7.8, lower a bit with muriatic acid. I like to keep mine around 7.5.
That’s it. No worries about floaters, CYA getting too high, etc,
What test kit did you get? Must not be one of the kids we recommend.
The tablets are not going to add the stabilizer that quickly. They tend to slowly build up the cya. But while the cya is low, the chlorine is destroyed very quickly by the Sun.
