Day 1.5 of the SLAM. FC target 12 CYA 30. Brushing and vacuuming 2xday. Checking and adding every 2-4 hours. Open to all suggestions. Thank you!
Got it! Thank you.Dog approved!Based on your CYA of 40, your SLAM FC level is 16. Wasn't sure if you caught that. FC/CYA Levels
Also, at a CYA of 40 your SLAM level is 16 ppm for FC so ensure to keep it up there and continue. Then do the Overnight Chlorine Loss TestHello ! Started slamming on Friday. Here are Wednesday stats…
Ph: 7.8
TA: 130
FC: 10
CC: 0
CYA: 40
OCLT: less than 1 point
Water is CLEAR! Pressure holding. Vacuumed and brushed again today. Shall we start working on the Ph? Should we allow the FC to drift now?
Thank you all. We read a bunch and trusted the process.View attachment 346047
I cant tell from the picture if it is crystal clear. If so and you have passed the OCLT, I would keep it at SLAM level for another day or two. The big rookie move is to end the SLAM as quickly as possible. Holding it for another day or two will ensure that you have killed everything so that you dont need to do this again.
