Pool was filled, after re-plaster, with city water. Same pool will be maintained on well water.
Tested the well water with my brand new Taylor K2006C test kit.
It shows:
Cal Hardness = 220
PH= 7.4
TA= 370 (wow)
Currently the pool is at:
PH=7.4
TA= 110
FC= 2.0 ppm
CC= 0.0 ppm
Cal hardness= 110
CYA= 30
CSI= -0.3
Plan for TA is to lower PH to 7.0-7.2 and hope TA drops. Running pump 12hrs/day with spa overflow aireation (sp?). CYA is right at lower limit and will only go up since I use trichlor tabs occasionally. I know the Cal Hardness needs to be higher but fill water should bring that up slowly. Just not sure how long it can be low and not effect the new plaster. Thoughts on Cal Hardness and/or TA plan??
It shows:
Cal Hardness = 220
PH= 7.4
TA= 370 (wow)
PH=7.4
TA= 110
FC= 2.0 ppm
CC= 0.0 ppm
Cal hardness= 110
CYA= 30
CSI= -0.3
