Hi guys.
I’ve been using the trouble free method since day 1. I chlorinate my pool with liquid chlorine and balance PH with muriatic acid
I use fiber clear to aid filtration and pool was as clear as polished.
But...
Last couple of week Pool was cloudy. All tests are as good as it gets so I thought that the filter was not doing it’s job correctly even though filter pressure was ok. So I decided to buy a chemical filter cleaner. GLB filter fresh. I poured the cleaner thru the skimmer while backwashing, let it go to the filter and let it do it’s job for 12 hours.
Pressure did not change but after two days of normal filtration it looks great and clear again.
So I cheated, just wanted to confess. And I’d do it again.
I’ll stay as close as trouble free system as I can but sometimes it needs a bit of help.
But...
