- May 16, 2011
- 1,184
- Plaster
- Pentair Intellichlor IC-60
I ALWAYS chase a tooled joint with a partner saw and diamond dry blade. (a circular saw with a concrete blade will work, but you'll be at it a while). I've seen countless times where the inevitable shrinkage crack happens ALONG SIDE of a tooled joint. This cut must be made as soon as the concrete will cut without raveling, but under no circumstances should it be more than 24 hours after the pour. The cut should be at least 1 inch deep to assure that the slab is weakened enough, as compared to the surrounding concrete to assure the crack happens where you want it. And as Brian has advised before, the less water in the mix, the less shrinkage will occur.
Your concrete will only turn out as well as the finishers working it. If they're in a hurry and close up the surface too early (before the bleed water rises) or if they are constantly "baptizing" it with a water-soaked brush, you will get spalling and delamination. It happens more frequently up north where there are multiple freeze/thaw cycles, but it can happen in any climate.
In closing, the best thing you can do is keep your concrete damp the first week of the cure. Light misting (and I mean light, during the first couple days) will keep the concrete damp and aid in hydration. (Concrete doesn't dry, it CURES). This will also slow the shrinkage rate and limit stress cracking. In other words, bond with your slab, as some here like to put it.
Thank you, BigE. This is all very helpful.
Snap Cap makes a nice clean expansion joint ready for sealant, such as a Sonneborn NP-1.
http://www.wrmeadows.com/plastic-joint-materials/
Thanks! I will check this out. Looks like the pour will be Friday.
