Hi all,
I found a few threads here comparing WaterGuru results to manual measurements, but all spot checks. I wondered if anyone has significant data on this?
I've had mine a little over a month and compiled some results. If there were consistent offsets between the measurements, even within a limited FC/pH range (as long as it's the acceptable range), WG seems like a great solution. Based on the limited data below, I'm on the fence about keeping it.
Unfortunately, after eliminating all the days where I measured with my Taylor k-2006 prior to WG's measurement (meaning chemicals may have been added between the two measurements), and a few measurements where I was SLAMing, I only have 8 days of solid data. Most of the data indicate more or less predictable offsets (better for FC than pH), but there are a couple exceptions, and I have too few points to know if they can be ignored. I also haven't analyzed how reproducible my manual measurements are, so that could be a factor those days as well.
If anyone else has a correlation with more data, it would be great to see.
Matt
Matt
