- Sep 1, 2011
- 545
- Plaster
- CircuPool Universal40
Next steps, ignore if already done:
1. . Go back to skimmers, where the pump is taking suction from, and verify that you are not drawing air in from there, either with too much flow, improper level, or a stuck weir door.
2. Replace all O-rings (basket cover, drain ports, suction line union) with new o-rings liberally lubricated with silicone grease for pools (Magic Lube II or equivalent)
3. When reinstalling, make sure the o-rings are properly aligned, not twisted, and properly seated.
4. Replace PVC in suction line from the pump back to the first joint.
