Hello,
My pool has two waterfalls on two pumps that are separate from the main filter pump. Each waterfall is on a dedicated 1.5hp single speed pump. Each pump is fed by two suction ports (why are there two? Is one a backup? I assume they are plumbed together underground before the pump.)
We never use one of the waterfalls because the fall is several feet and the sound is far too loud for 'ambience'. I have a spare vsp pump that I want to connect to the waterfalls. I want to plumb both waterfalls to the vsp pump with a Jandy valve to each waterfall on the supply side of the pump. The idea is with the pump at high speed and the Jandy valves wide open, each waterfall will flow at max. If I want one waterfall to have less or none, the valve can be closed.
My question is, should I plumb the suction side from the old pumps together into one for the vsp pump or only use one of the suction lines and cap the other one? Thanks in advance for any input.
