Hi! New member, first post.
I turned on our spa and the waterfall did not stop, so obviously the spa cannot heat. We have not actually used the spa since the winter, which was a cold one for Georgia so we had freeze protection on multiple times. We had the same issue either last year or the year before and it was one of the valves that was turned, but I am not sure which one.
First photo is with spa off, last photo with the labels is spa on. The valve with the red arrow, A, turns when the spa is on. I suspect the issue is with B, but want to be sure before I start turning valves. Second photo is pump area.
Thank you very much!
E
System is Hayward OmniLogic, pool was completed in spring 2020, inground.
E
